No, but what's your point? Are you saying that there is no momentum?Sibelius Hindemith wrote: ↑Tue May 16, 2023 4:28 pmNose tackles don't run in space much though do they?
Here is the same calulation based on Young's 10 yard. There would be a negligible difference in his 10 yard that would impact his momentum
304lbs, 0.545m/s = 543 lb-ft/s
320lbs, 0.545m/s = 572 lb-ft/s
That is still 29 lb-ft/s gained with the added weight. Likely less given it's just a launch step or two. But having the added weight certainly adds a benefit upon engagement. Maybe he adds another 5 or so pounds without impacting his launch time and adds to his momentum.
