Roughing the Passer
Roughing the Passer
ROUGHING THE PASSER
Because the act of passing often puts the quarterback (or any other player attempting a pass) in a position where he is particularly vulnerable to injury, special rules against roughing the passer apply. The Referee has principal responsibility for enforcing these rules. Any physical acts against a player who is in a passing posture (i.e. before, during, or after a pass) which, in the Referee’s judgment, are unwarranted by the circumstances of the play will be called as fouls. The Referee will be guided by the following principles:
Roughing will be called if, in the Referee’s judgment, a pass rusher clearly should have known that the ball had already left the passer’s hand before contact was made; pass rushers are responsible for being aware of the position of the ball in passing situations; the Referee will use the release of the ball from the passer’s hand as his guideline that the passer is now fully protected; once a pass has been released by a passer, a rushing defender may make direct contact with the passer only up through the rusher’s first step after such release (prior to second step hitting the ground); thereafter the rusher must be making an attempt to avoid contact and must not continue to “drive through” or otherwise forcibly contact the passer; incidental or inadvertent contact by a player who is easing up or being blocked into the passer will not be considered significant.
A rushing defender is prohibited from committing such intimidating and punishing acts as “stuffing” a passer into the ground or unnecessarily wrestling or driving him down after the passer has thrown the ball, even if the rusher makes his initial contact with the passer within the one-step limitation provided for in (a) above. When tackling a passer who is in a defenseless posture (e.g., during or just after throwing a pass), a defensive player must not unnecessarily or violently throw him down or land on top of him with all or most of the defender’s weight. Instead, the defensive player must strive to wrap up the passer with the defensive player’s arms and not land on the passer with all or most of his body weight.
In covering the passer position, Referees will be particularly alert to fouls in which defenders impermissibly use the helmet and/or facemask to hit the passer, or use hands, arms, or other parts of the body to hit the passer forcibly in the head or neck area (see also the other unnecessary roughness rules covering these subjects). A defensive player must not use his helmet against a passer who is in a defenseless posture—for example, (1) forcibly hitting the passer’s head or neck area with the helmet or facemask, even if the initial contact of the defender’s helmet or facemask is lower than the passer’s neck, and regardless of whether the defensive player also uses his arms to tackle the passer by encircling or grasping him; or (2) lowering the head and making forcible contact with any part of the helmet against any part of the passer’s body. This rule does not prohibit incidental contact by the mask or non-crown parts of the helmet in the course of a conventional tackle on a passer.
A defensive player is prohibited from clubbing the arm of a passer during a pass or just after a pass has been thrown; however, a defensive player may grasp, pull, or otherwise make normal contact with a passer’s arm in attempting to tackle him.
A rushing defender is prohibited from forcibly hitting in the knee area or below a passer who has one or both feet on the ground, even if the initial contact is above the knee. It is not a foul if the defender is blocked (or fouled) into the passer and has no opportunity to avoid him.
Notes
A defender cannot initiate a roll or lunge and forcibly hit the passer in the knee area or below, even if he is being contacted by another player.
It is not a foul if the defender swipes or grabs a passer in the knee area or below in an attempt to tackle him, provided he does not make forcible contact with the helmet, shoulder, chest, or forearm.
A passer who is standing still or fading backward after the ball has left his hand is obviously out of the play and must not be unnecessarily contacted by an opponent through the end of the down or until the passer becomes a blocker, or a runner, or, in the event of a change of possession during the down, until he assumes a distinctly defensive position. However, at any time after the change of possession, it is a foul if:
an opponent forcibly hits the quarterback’s head or neck area with his helmet, facemask, forearm, or shoulder
if an opponent lowers his head and makes forcible contact with any part of his helmet against any part of the passer’s body. This provision does not prohibit incidental contact by the mask or the helmet in the course of a conventional block.
When the passer goes outside the pocket area and either continues moving with the ball (without attempting to advance the ball as a runner) or throws while on the run, he loses the protection of the one-step rule provided for in (a) above, and the protection against a low hit provided for in (e) above, but he remains covered by all the other special protections afforded to a passer in the pocket (b, c, d, and f), as well as the regular unnecessary roughness rules applicable to all player positions. If the passer stops behind the line and clearly establishes a passing posture, he will then be covered by all of the special protections for passers.
The Referee must blow the play dead as soon as the passer is clearly in the grasp and control of any tackler behind the line, and the passer’s safety is in jeopardy.
Note: A player who initiates contact against a passer is responsible for avoiding an illegal act. This includes illegal contact that may occur during the process of attempting to dislodge the ball. A standard of strict liability applies for any contact against a passer, irrespective of any acts by the passer, such as ducking his head or curling up his body in anticipation of contact.
Penalty: For Roughing the Passer: Loss of 15 yards and an automatic first down; disqualification if flagrant.
Notes
When in doubt about a roughness call or potentially dangerous tactic against the quarterback, the Referee should always call roughing the passer.
See 8-6-1-c–d for personal fouls prior to completion or interception.
*Bold text denotes 2018 rule changes
Notes
Notes
Re: Roughing the Passer
I take it the bolded part is the reason people believe Ziggy should not have been flagged on the hit to Goff, because he did hit him in the knee area.A rushing defender is prohibited from forcibly hitting in the knee area or below a passer who has one or both feet on the ground, even if the initial contact is above the knee. It is not a foul if the defender is blocked (or fouled) into the passer and has no opportunity to avoid him.
On the Clay Mathews hit on Wilson, the bolded part may apply. In other words, he did more than just make contact with his shoulder pad. He also shoved him to increase the force with which he was driven into the ground. Also, from the only angle of the hit that seems to be available on the internet, it appears that Mathew's helmet may have struck Wilson's facemask following the initial contact. I don't know if that would be considered incidental as the main reason for that was Wilson's head dipping forward towards Mathew's helmet.When tackling a passer who is in a defenseless posture (e.g., during or just after throwing a pass), a defensive player must not unnecessarily or violently throw him down or land on top of him with all or most of the defender’s weight.
I agree with Sibelius and he identified the exact two plays from the Rams game that I wanted to compare to the rule. I was really frustrated by the Ziggy roughing call at the time. My theory is a rusher needs to be able to tackle the QB, as long as they don't go afoul the namby pamby protections the modern day NFL QB gets. For me, the going low rule added in to the mix makes the D lineman's job nearly impossible. You can't hit them high, you can't hit them low. What Ziggy did was NOT something that was likely to cripple a QB. He lunged full out to try and tackle the QB. That's his job. There was nothing malicious going on.Sibelius Hindemith wrote: ↑Sun Oct 06, 2019 9:41 pmI take it the bolded part is the reason people believe Ziggy should not have been flagged on the hit to Goff, because he did hit him in the knee area.A rushing defender is prohibited from forcibly hitting in the knee area or below a passer who has one or both feet on the ground, even if the initial contact is above the knee. It is not a foul if the defender is blocked (or fouled) into the passer and has no opportunity to avoid him.On the Clay Mathews hit on Wilson, the bolded part may apply. In other words, he did more than just make contact with his shoulder pad. He also shoved him to increase the force with which he was driven into the ground. Also, from the only angle of the hit that seems to be available on the internet, it appears that Mathew's helmet may have struck Wilson's facemask following the initial contact. I don't know if that would be considered incidental as the main reason for that was Wilson's head dipping forward towards Mathew's helmet.When tackling a passer who is in a defenseless posture (e.g., during or just after throwing a pass), a defensive player must not unnecessarily or violently throw him down or land on top of him with all or most of the defender’s weight.
With Matthews, he was laying a lick on RW. Plain and simple. In both penalties the ball had already left, but just barely. Packers fans and Troy Aikeman want to point to Matthews and say it was a fair hit because it was with his shoulder. But I would say what Matthews did was definitely unnecessary contact. You really can't appreciate the Matthews hit unless it's viewed at full speed. He popped him.
No, what happened?
Is this what you're referring to?
Cowboys coach Jason Garrett was penalized for unsportsmanlike conduct when he slammed the challenge flag in front of side judge Scott Edwards after Edwards ruled Cooper out of bounds when the receiver got both feet in on a catch. The call was reversed on replay, but the Cowboys started first-and-25 because of the penalty. Elliott, who had 62 yards rushing, caught a 26-yard pass on the next play.
- Oso Dorado
[/quote]Cowboys coach Jason Garrett was penalized for unsportsmanlike conduct when he slammed the challenge flag in front of side judge Scott Edwards after Edwards ruled Cooper out of bounds when the receiver got both feet in on a catch. The call was reversed on replay, but the Cowboys started first-and-25 because of the penalty. Elliott, who had 62 yards rushing, caught a 26-yard pass on the next play.
It appeared that Garrett said something to the ref at that point, I think it was words more than the slamming of the flag that got him in trouble. (Just an opinion, however)
There was a fairly marginal roughing call in the Raiders - Bears game, when Hurst hit Daniels as he was releasing the ball, causing an interception, but the refs called roughing on the play, because he took Daniels to the ground. He didn't land on top of him, but it was a close thing. Still, the line between a great defensive play and a penalty is razor thin.
So, did they rule that Earl's hit on Rudolph was inadvertent since he wasn't ejected?
Did you see that the couldn't get the cart to haul him off the field started because of operator error. Ok, now that is a stupid NFL thing.Sibelius Hindemith wrote: ↑Mon Oct 07, 2019 2:42 pmSo, did they rule that Earl's hit on Rudolph was inadvertent since he wasn't ejected?
Here's pretty much the same flag as what Ziggy got.
https://www.12up.com/posts/video-steele ... dphbds43tt
Neither of those tackles are going to hurt a QB.
